RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 01-13-2006 | 03:33 PM
  #1750
futura
Default RE: E-FLIGHT BLADE CP
yea, I've saved a couple that way....when the bend was obvious at least. the bend is usually at the collar anyway. In my case, I have the upgraded LG and bell hiller head with seperate electronics strapped on under the main gear...its a pain to allways be pulling things apart to get that slight vibe outa the works. It just bends to easily...like on a hard landing when nothing else breaks.
I want a harder main shaft.
Someone on another forum mentiong 3mm drill rod cut down and drilled for the pin holes.
...could use that with the Esky gear and I wouldn't have to disassemble the frame. its a thought!
