RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 01-13-2006 | 05:14 PM
  #1751
catfight
Default RE: E-FLIGHT BLADE CP
doomgaze,
The 3rd bb goes in the outer end of the grips (where the blade gets pinched)- you just insert 2 sets end to end in the opening. You need the correct grips made just for the 3bb because that hole is drilled deeper. The assembly procedure other than that is the same.
Good flyin'
