RCU Forums - View Single Post - MY KADET LT-40 BUILD
Old 01-13-2006 | 06:32 PM
  #190
shd3920
Default RE: MY KADET LT-40 BUILD
ORIGINAL: bruce88123
Which pushrod connector(s) is popping off? Is it popping off on it's own or when servo moves or when you touch it or when? Best photo close-up please
bruce, welcome back, don't worry about any delays you may have, just hope you are feeling better. I have taken out my Air Scout from storage and I am going to start working on that again. I have to put the LT-40 away for now, as I ran out of covering material for the wing. I have not had any connectors pop off YET, I was just wondering if anyone ever has had them fall off, and if they have I would have plenty of time to substitute them before it was all permanent.
I have almost completed the pushrod problems of the buzzing. All but the nosegear buzzes now, but very lightly at the moment. I had to rip out the thin pushrod tube that came with the kit (I just could not get the rod to slide smoothly in it) from the fuselage and replaced it with a wider red nylon pushrod tube, and I am using a Z-bend at the steering end with a pushrod connection at the servo end. An occassional buzz still sounds once in a while, is that little bit of buzz something to worry about?
