RE: Impact cg
Keith, I had the CG as much as .625 behind the wing tube on the plane also. I had done a layout of the wing to find MAC as Jim did with a similar result. The plane does hold 45's requiring some stick pressure to hold inverted, which is what im used to.
When you say it didnt roll right what was it doing that bugged you?
