RCU Forums - View Single Post - Dual RX Battery & Switch
Old 01-14-2006 | 06:05 AM
  #47
The Raven's Avatar
The Raven
Default RE: Dual RX Battery & Switch
ORIGINAL: stek79
Jim, thanks for the infos, how that perfect switch works?
A wild guess to how it works is that the switch is momentary contact which then triggers transistored switching to pass the power through the regulator. In simple terms it's more like a relay, the switch is super low current which then signals the transistored switch in the regulator to do it's stuff. Even if I'm only partly right, that's a pretty clever way to do it.
