RE: YTD725 Information needed
In the extreme situation the short shaft would.
Don't forget, the longer the hub, the greater the vibration. This problem increases more rapidly than your increase in length. Just a little change in length makes a considerable difference.
You can make your long shaft engine as long as what the crankshaft will aloow you to use it as a prop shaft.
You can cut the long shaft off and thread it and make a hub as long as you could on a short shft engine by threading the hub onto the shaft.
Another point of view is that the long shaft engines are usually close to 3/8" whereas the short shaft engines are 5/16" or 8mm in diameter.
Enjoy,
Jim
