First time starting .46 AX by OS engines
Hi all,
I just got the new OS engine .46AX. I tried starting it with the TorqueMaster 90 and there doesn't seem to be enough torque to turn the engine over past the tight area at the top of the stroke. The engine manual states the the tightness is normal, since the gaps are optimized at operating temperature. I can turn it over by hand, but the starter just can't do it.
Has anyone had this problem before? Suggestions?
Thanks in advance.
JJ
