It's fun. If you build the alignment tabs in the fuse and then use wood glue, you can just place the formers in and use rubber bands to keep the fuse strait. (I'd CA the alignment tabs in to save time) The wing shouldn't be much trouble for you either. One tool that makes the wing go together easily is the House of Balsa wing rib alignment tool. You will want to read through the instructions first and build carefully.(especially on the fuse alignment tabs) I'd be glad to help, but I built this a while back. I'm still familiar with the plane though.
Woops
