RCU Forums - View Single Post - BVM KingCat for AFPD?
Old 01-14-2006 | 03:19 PM
  #39
TWRC
Default RE: BVM KingCat for AFPD?
That's odd...?????? your structure looks right. There must be something simple we are not seeing. May I have the TMD and TMG files to look at? [email protected]
What are the results your seeing? Did you modify the object File with a "ring" Object or is aerofly reading the object file from the Harpoon folder. Aerofly will do this if the specific aircraft folder dose not have the object defined in the TMD file aerofly will sometimes look elsewhere for if. I've seen this before, and then you could change the location lines in the Kingcat's TMD file but will make no difference because it's reading the Harpoon's TMD file. You could answer this question by temporarily removing the Harpoon form the aircraft folder and run the Kingcat. if you don't see the "Ring" graphic you know aerofly was reading the Harpoon files looking for the Object "Ring" and thus the TMD file that goes alone with it. It that case I can modify the .suf file and create a new Jetcat.obj file for the King Cat. I'm just throwing out possibilities but would need to see the TMD/TMG files to know for sure what exacly the problem is. I Know we can fix it
Pat
