RE: steer straight
Yes that is it. When I set mine I measure from the bottom of the plate up to the bottom of the black knurled nut. Factory spec for a Genesis is 6.0 mm. I am not sure if it's different on a Nemesis. Turning the nut up (towards the top of the truck) will tighten the servo saver. Be careful not to go to tight or you'll ruin your servo.
