RCU Forums - View Single Post - ARC Jupiter
Thread: ARC Jupiter
Old 01-14-2006 | 06:13 PM
red head
Default RE: ARC Jupiter
AAC --- you shouldn't need a metal bolt for your wing, I've been using the nylon bolt that comes with the plane for years. I did replace the one I have now as I had used it a LONG time and it was getting hard to tighten. You may have to tighten it a few times and maybe even reef on it a bit. I sometimes think I'm tightening it to much but in about 8 years I've never broke one ( except on a hard ground loop when the wind got the Ready ).
I have a coin that fits the slot of the bolt that I filed flat on one side that I use to tighten mine. If you can find a Canadian quarter they work great and just go along with your change in the pocket. Just don't try to buy anything with it, the stores have NO sence of humor for some reason.
When you get really comfortable with the plane get back to me and I'll tell you how to Have some real fun with it, but not till you are REAL comfortable with it.
Another little hint I forgot about : I don't know if you SCORED all your glue areas or not I hope so but anyway -- On your landing gear bulkhead -- go back in and run some more medium CA all along the mount edges. They have a tendency to loosen up after a while. I've had to go back and reglue one. Not from hard landings, just rough ground --- --- and if you believe that I've got a couple bridges I'd like to sell you. ( ha ha ) Hope this helps and keep us informed how you are doing. ENJOY !!! RED
