Do you need revo when using your own TX?
Maybe thats my issue with the gyro gain acting like the pot adjustment.
ORIGINAL: redman7722
Ok, here is what I got. "My heli fly's fine with this may be a little diff. to yours".
Reverse channels 1 and 3
in swash I have hr3
ail -50%
ele +58%
pit +64%
Go to parameter and make sure you are in "ppm"
th-crv
5-95
4-75
3-50
2-25
1-0
pit-crv
5-63
4-58.5
3-56.5
2-53
1-46.5
This gives me from -1 to +9 pitch range. I got these settings using a pitch guage.
REVO mix you have to adjust while flying to get it dailed in but I got
HI -37%
LO -37%
Hover pitch and throttle I do not have turned on but you have to play with it to get it were you want it.
The pitch curves will vary depending on how well your heli is set up. You really need a pitch guage.
Used pitch gauge for idle 1 this is what I have for it
th-crv
5-100
4-70
3-50
2-70
1-100
pit crv
5-62
4-59
3-48.5
2-45
1-36.5
I am not good enough to fly inverted so negative pitch is untested. Hope this helps but remember REVO and Offsets are best adjusted on the fly for best effect. Just go into revo then enter a hoover then give sharp throttle if heli spins left take away from hi setting or vice versa. Then do opposite for lo setting get some altitude then decrease throttle sharply if heli spins right take away from lo setting and so on.
If pitch crv does not work for you spool up to half throttle the adjust pitch until it gets light on the skids then go from there for posistion 4,5,2,1 . This should get you going in the right direction.
Also I have aerobatic kit and 11.1 lipo so this setup will make a little difference.
