RE: E-FLIGHT BLADE CP
Zooland1:
Yes it's tight. might make a better flier out of me because of the limited space. It's certanly hit the walls, door & garbage pails enought times, (rather than me) -- Never had a tilt over-- despite the many rebuilds & repairs. At least you become an expert in the mechanics of the machine, though all heli's are pretty much the same. I usually hover in the 3-5 Ft range (Afcraid to take it higher with the 61/2 -7 Ft ceiling.) At times I I'm literally standing over it at 1-2 Ft Alt while in a rock steady hover--"Funny feeling"
The only Mod I did was adding a LIPO, the 9 tooth pinion Motor , and Symm blades. I'm really using the blade as a learning machine, and plan on a T-Rex or MX400 after I perfect Tail-out hovering. Have a Raptor 30 I built 6 Yrs ago which for various reasons has never been flown. Will take it out in the Spring-- Should be lots more stable and more easily flyable than these Micros.
Lloyd
