RE: First time starting .46 AX by OS engines
here is a trick that is fairly common on rc car/truck engines (those things are REALLY tight before breakin, and if you are pulling with a pull starter the oneway will just slip) anyway, loosen the glowplug just enough to serve as a compression release. doesn't take much, and as soon as it is running you can tighten it back up.
