RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 01-15-2006 | 01:44 AM
  #3991
raideron's Avatar
raideron
Default RE: U-Can-Do 3d 46?
Hey Rob... I like yours:-)... Did you strenghten the fuse??.. I was going to take the
stripes off, the green came off easy but the the white was stubburn and I had blue
So..... Guess your tail wheel is the same as the V2... A bit soft... I had a carbon
fiber tube so I slit it down the center(almost) glued and pressed it on the tailwire
it seemed to help it a bit.. Did you ever weigh yours?? They should be lighter than
the V2... Mine came in at about 5# with the mini throttle servo HS85BB, HS 425's
and a HS 635HB on the rudder on 6v.. all stock equip. and a JR charge switch..
Jack... I'm not sure, but since the holes were pre-drilled, they were alittle taller than
the tank and since the stock tank does not lean against the wing along with me useing
packing tape around my tank(YS) and using the "Hitec" receiver pad as my tank foam
all was able to "slip back some" under high throttle.. But I still think it was just a bad
tie... silicone will work, I went with the sticky backed velcro/C.A. Tank won't move now..
4 hours..... Hey quit bragging...I took seven days)))))))))))
I soldered both my tail wires also... that way I can use just one extension on the rec.
and still have easy excess for the wing removal... But I have yet to take the wing off..
I also re-soldering my battery connection (the 6v that did my "Do" in) and I'm using it...
It had better be good... Or I'll crash:-((
Have a Good Maiden.... I think you'll like it..
Ohhh... The "Do" thread........ Gary started this off the thread with his pic of his un-"Do"
plane:-)
OK, I'm back on track.... I'm starting to strenghten the nose(S-100) and gear area on
my yet... New, Wing-less "Do"... With my Great thinking I almost started epoxing the
tail feathers... But then caught myself.......... :-0
