RE: Flatana Setup question
That looks great, only thing is the motor and esc are good to 12+ amps but the battery is really not quite up to that. If you prop down a tad and take it easy on the battery it should be a nice super light setup. CG MAY be an issue as I used 900s with a heavy park 370 inrunner and GB and still had the battery velcroed right up against the motor.
I'd suggest trying the new 900 TP prolites... they should be great and 2.2ish ounces. 1320s will be plenty but start adding weight but might make flying in slightly windier weather a little better. I like light though. good luck and have fun.
oh, just noticed the stock prop thing - I'd do a little research or wait for reponses on suggestions - I can't comment on that one...
