RE: .21 engine
I'v used o.s plugs before and the guy from my LHS told me just to use standard glow plugs and he's been racing NITRO's for years, but ill give it ago. the low speed is flush with the side of the engine thats usually normal but for some reason the only high speed setting that my engine'll run from bottom to top perfectly is at about 3.75 to 4 turns. If it runs right then it doesn't reaaly matter to me i just found it odd that its normally around 2.5 to 3 but my one's a full turn more than usuall. Would anything cause this. i don't often mess around with NITRO's im into 1/5 GAS eninges and i'm great at tuning them and didn't realise that i'm actually much better than i thought at tuning these little engines (Not To Blow My Own Trumpet) i just haven't ever had one thats played up enough for me to have to try hard at it. If you or anyone else has any ideas why the high end valve has to be set so high drop me a PM or post back. THANKS
..........TURNELL..........
