RCU Forums - View Single Post - BRIO Construction by the numbers
Old 01-15-2006 | 08:43 PM
Don Szczur's Avatar
Don Szczur
Default RE: BRIO Construction by the numbers
Here are the pictures of the engine mount setup. Note that the Hyde mount is off set so that the top of the cylinder is rotated 1/2 inch away from the exhaust port. If you are running YS, this provides the extra clearance so you don't have to put an opening on the side of the chin cowl for header clearance.
ID:	388433   Click image for larger version
ID:	388434   Click image for larger version
