That a nice set up and looks good . You said it turned on its own ? MAYBE you have a metal to metal contact causing a radio glitch affecting just your rudder servo . You might not have enough rudder blade in the air flow making it not turn . MAYBE move the blades apart a couple or three inches and add a little to the height . Just some things you might look at .
