RCU Forums - View Single Post - inverted engines
Old 01-15-2006 | 09:24 PM
Cyclic Hardover's Avatar
Cyclic Hardover
Default RE: inverted engines
The location/height of your fuel tank is the main issue. If you invert your engine and install the tank in the stock position , you will have problems. If you lower the tank to "at or slightly below the carb line" then you should be fine.
