RE: Hitec programmer
I see
So the programming of the servos should be values that will set the center in between the two end points and only then we will have linearity?
On the DOD vids it looks like it is not in between the two (one value is too high than the other one in relation to the center reference)
Another question I had is:
All the servos on a multiple servos surface must travel the same distance left and right, that we know
But all the servos should travel the same distance as well? For example all should travel 55 degrees left and right or each servo will have its own even values?
I’m also having a problem with some Hitec servos that don’t center
Even after rest and set them up again they don’t center. Every time I move the stick and release it the center is different (new JR 9X).
The pulse read shows a different value every time as well.
Any advice about that?
Thanks you very much for your kind help
