Small Servos for use with Kraft Radios
hello,
are you using Kraft recievers ? if so you have to use Kraft servos
as they use a much higher signal voltage than modern servos
4 volts as compared to .4 ,I think ,
If your using a R.C.D. reciever then any modern servo will work
just fine as this is what I used to use with my kraft single stick
