RE: Century scale muffler.... can't get it to fit!
Hi! Ok either I'm not following you or you're not following me... movement of the throttle arm doesn't bring it into contact with the scale muffler.... the entire throttle arm is against the muffler. The Century scale muffler is a large flat rectangular affair designed to fit inside a scale fuse... as such it pretty much covers the entire right side of the engine. When bolted up though mine is in a bind against the throttle arm... position of the throttle has no bearing on it.
Am I making sense here or do I need to post a pic? This is hard to describe I guess.
Thanks!
- Michael
