RE: Sig Somethin' Extra Build
You may want to cover or fuel-proof the wing roots. Even though they are not directly exposed, you will certainly get residue that can seep back from the joint and will soak into the wood and under your covering since it isn't firmly ironed down all the way to the edge. Crank a trim iron up to high and go over the edges on the root to shrink and seal them.
