RE: Prop fitting, wing dowels and RX antenna fitting
I've bought a chicken finger but I'm starting to think that it's a bit too risky.
Before putting the prop where it needs to go, do you turn the crank anti-clockwise until you feel the resistance (due to the compression) ?
And then tighten the prop as tight as I can with a six inch wrench ?
