RCU Forums - View Single Post - BRIO Construction by the numbers
Old 01-16-2006 | 12:33 PM
Don Szczur's Avatar
Don Szczur
Default RE: BRIO Construction by the numbers
The rudder is built-up. Three 1/4 inch ribs are in the center, where the rudder horn dowl will go.
Below are some additional pictures on the elevator adjusters. It only took a few minutes to do this. The outer nyrod material is glued from the inside to the sheeting and aligned with the adjuster screws on the top and bottom.
ID:	388921   Click image for larger version
ID:	388922   Click image for larger version
ID:	388923   Click image for larger version
ID:	388924   Click image for larger version
