RE: Sig Somethin' Extra Build
If you were complaining about fumes I'd understand but if sanding is your biggest concern I say you need to use less and be neat so you don't have to sand CA. The build goes so frikken fast with CA and the fuse doublers are the only area where alphatic is called for.
