RCU Forums - View Single Post - Aileron hinge question?
Old 01-16-2006 | 05:51 PM
Mode One
Default RE: Aileron hinge question?
Actually the hinges supplied, if true hinges are the very good. However, the CA hinges work just fine and are much easier to install. Just test them, when you are done to make sure they are secure, by pulling on the hinge fairly hard. If they fail, it is better to have had them fail on the ground, then in the air. Do you know how to install them?
