RCU Forums - View Single Post - Sig Somethin' Extra Build
Old 01-16-2006 | 08:57 PM
  #64
tuwood's Avatar
tuwood
Default RE: Sig Somethin' Extra Build
ORIGINAL: BasinBum
If you were complaining about fumes I'd understand but if sanding is your biggest concern I say you need to use less and be neat so you don't have to sand CA. The build goes so frikken fast with CA and the fuse doublers are the only area where alphatic is called for.
But the fumes make me so happy! [sm=sunsmiley.gif]
I actually planned on using wood glue on my kit when I started but after trying to glue my first two pieces together I decide that I was far too impatient for that.
I did use too much CA on several areas on the first wing & the sanding was a nightmare. With the lessons learned on the first one & about half as much glue, the second wing came out very nice & I barely had to sand any CA. [8D]
