RE: BRIO Construction by the numbers
Next use a marker and mark where the hinges will be. I put them basically 4 inches apart on both the ailerons and the elevators. Next use the marker and blacken the sharp corner of the bevel, then carefully position the elevator or aileron up against the stab or wing, and press the surface against the stab or wing. This leave little lines which tell you exactly where to put the hinge slot.
