RE: BRIO Construction by the numbers
Final step is to sand the control surfaces so they blend in with the wing surface, trailing edge of the wing and wing tip to get a perfect match. Mark down where the slots are so after its covered, it will be easy finding the slots to glue on the control surfaces. I make mine 1 inch in from each end of the surface and then spaced 4 inches between hinges. This puts 6 in each aileron and 4 in each elevator.
Don
