RCU Forums - View Single Post - Vector push boat issue
Old 01-17-2006 | 12:19 AM
ib2525
Default RE: Vector push boat issue
I have had a look inside, seems it does do it out of water to an extent.... so took the transmitter apart... noticed a bit of wear on the contacts.... cleaned and back together...
I think one of the relays is a bit dodgy.. but will try again...
I may put a rudder on it in the end, but finding one the right size so far has been an issue... Its just easy for everyone to use, not too fast, doesnt need deep water, simple really. Might try to make one out of some scrap i have around..
Tested the draw out of water and each motor is pulling about 2 amps... they can handle 10 amps so i am hoping that they wont hit that.
It is going to be a retrivial boat for my 46" homelite powered enforcer.... if it will tow it.
Had a ball with it today tho, jumping small waves at the beach... pitty it kept cutting out, was getting alot of air... the 2 400's are a nice power boast.
