RE: mold making problem
Some will argue the point, but chopped mat is designed for use with polyester resin. In its raw form it is stiff as a board but the binder relaxes when poly is applied. Others say that epoxy can be used if you wad up the mat before using it. What does the manufacturer say about using it with mat. There was a thread that stated that one manufacturer said not to use it with mat. Regards.
