RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 01-17-2006 | 10:39 AM
  #2844
c016Y's Avatar
c016Y
Default RE: U Can Do 3D
Are you asking if you can use rubber bands to set the wing on the bottom of the plane? The answer is you don't. That is a bad design and a hassle anyways. The bolts are easier. The 2 bolts is a heck of a lot easier than most split wing aircraft. You have a bolt for each wing on the inside which is usually hard to get to and then you have to screw the canopy on... pain in the butt.
