RE: Radio Compatability
If you are POSITIVE it is an old Airtronics servo, you swap pin positinos of the outer red wire with the center black wire. You can easily do this by lifting the locking tab on the plug with ah X-acto knife and pulling the pin out of the shell. Then just plug them back with the red in the center. This will make it pin-compatible with the new universal "Z" plugs used in the later receivers.
