RCU Forums - View Single Post - Bdavison's E-flite Blade Assembly
Old 01-17-2006 | 10:46 PM
  #284
hellomynameisdookie
Default RE: Bdavison's E-flite Blade Assembly
ORIGINAL: The^Phenom
So what was his solution to that problem. Back to the 3BB?
As soon as a new 3bb grip was put on everything worked great.
The tail boom is glued in, you could try some debonder. Same with the tail motor housing. It seems some people's are glued in pretty good while others are just good enough to hold in place. If you're lucky it's just good enough to hold in place and it'll remove somewhat easily.
Yes, you'll have to take the wires off of the motor.
