RCU Forums - View Single Post - The O.S. v-spec problem
Old 01-17-2006 | 11:03 PM
J_Bone's Avatar
J_Bone
Default RE: The O.S. v-spec problem
That was the issue I was asking about in your other post. The OS TM and TZ's had that problem.
There is too much slop. RD Racing fixed it by installing a spacer between the piston and the rod. What that does is, it stops the rod from moving all the way over on the Journal and rubbing the back plate.
