RE: Help please: using angle template
if the plans call for you to glue in the top spar before setting the angle you mark the spar at the angle the template shows and then cut. if you set the top spar per the angle before you glue it in just lay the template on the plans standing up, set the top spar in place and then glue it just make sure you have the correct side of the template against the spars
