RE: Sig Somethin' Extra Build
I have the top of the wing sheeted, tubes in and secure. I've lifted the wing off the building board and I'm ready to sheet the bottom of the wing. The manual calls for a straight 1" board a little longer than the wing to set the trailing edge on. Both the spar on the bottom and the trailing edge need to be secured flat against the building surface. This wing is still a little flexible so I take it the mounting of the bottom sheeting along with the lower spar and trailing edges being parallel with the building surface will tie it all together and I wanna make sure I get this right. The wing is tapered so once pinned down this side will be flat while the other orientation will have the trailing edge a bit higher on one end than the other.
Am I thinking of this right?
Appreciate any input!
somegeek
