RCU Forums - View Single Post - new boat, same problem
Old 01-18-2006 | 08:25 AM
Mr Cajun Gator
Default RE: new boat, same problem
On some of my hulls I use bottom runners, as long as they are true to the center line of the boat it will not give any problems. Bob Smith Inds. makes a good 2 part epoxy(the only brand I use).
Tip for building with plywood, make sure that your work bench is completly flat. If your work bench is twisted so will be your boat.
