RCU Forums - View Single Post - Great Planes Pitts--cabane brackets--again
Old 11-25-2002 | 06:19 PM
  #32
amcross
Default Great Planes Pitts--cabane brackets--again
Hi, All! To clarify, yes, future kits are coming with an updated bracket; however, at this time we only have a small quantity, so PLEASE do not call us and ask for new because you THINK yours might ahve a probem. MOST users who are powering the model as called for are not having any difficulties whatsoever.
Please also be aware that we are NOT responsible for equipment failure caused by overpowering the airframe. Nearly every case of failed brackets we're aware of were powered by single cylinder gasoline engines that exceed the range for which teh model was designed, tested, recommended, sold, AND WARRANTED. So if you're swinging more power plant than what the model was designed for, then this is exactly the type of item you yourself have to make a decision if it requires modification and you are entirely on your own to do so.
