RCU Forums - View Single Post - The O.S. v-spec problem
Old 01-18-2006 | 10:07 PM
clone3's Avatar
clone3
Default RE: The O.S. v-spec problem
There is too much space for the top of rod on wrist pin. The true problem is that the sleeve and crank align. are off. If they were correct the rod would run-true(center) without grinding on the back-plate.-------------------check the pic's----I'm done with O.S.[:@]
ID:	390476   Click image for larger version
ID:	390477   Click image for larger version
