RCU Forums - View Single Post - Midwest Extra 300xs Build
Old 01-19-2006 | 08:49 PM
  #157
Digger44's Avatar
Digger44
Default RE: Midwest Extra 300xs Build
Now it's time to install the hinge points so I drew a center line on the trailing edge of the wing and the leading edge of the aileron. Then, over the plans, marked the hinge point locations on both edges. Drilled 1/16" hole to be used as a pilot for the larger pin size.
ID:	391052   Click image for larger version
ID:	391053   Click image for larger version
