RCU Forums - View Single Post - New to this, lookign for a wing jig
Old 01-19-2006 | 09:03 PM
EXCAP232
My Feedback: (12)
Default RE: New to this, lookign for a wing jig
Sneasle,
Welcome to RCU. I'ts good to hear from folks at my old Alma Mater! War Eagle!
Building a lot of wings on an Ajusto-Jig would be quite an undertaking. It is a good tool however it has it's limitations since each rib must be drilled to be attached to the jig. If all ribs are the same (no taper) then they could be gang drilled which would save some time. The advantage to this jig is a wing can be build in essentially one piece with dihedral built in.
There are many other options that would lead to building multiples. Setting up a purpose built jig with holders specific to the wing would have it's advantages. If all the wings you plan to build are different in nature then something changeable may be in order. The Adjusto-Jig would do this however it does take a bit of time to set up. Setting up a jig with magnetic holders would be a good option. There is an offering from Tower however building your own will save you $$ and you will be able to set up for your needed preferences. Let me know a little more of the design(s) and I'll try to provide additional information.
Check out http://www.rcuniverse.com/forum/forumid_174/tt.htm which is the scratch building / aircraft design / 3d cad forum. It will have a wealth of information helpful to your mission.
Best regards,
EXCAP232
