Help - Irvine .53 does not stop?
It is not your front bearing that is causing this. The cinch bolt that holds the carb in on these has a tendancy to work loose but sounds like you have already worked with that. Have you checked the bolts on the backplate ?. Loose bolts here will cause the problem you mention.
