RCU Forums - View Single Post - Showtime
Thread: Showtime
Old 01-20-2006 | 01:20 AM
  #1398
rcfury's Avatar
rcfury
Default RE: Showtime
Well getting back on the showtime subject... I ran into a little snag upon building the rest of the fuse as my wing is still at horizon becasue of a cracked sheeting on the LE. All the builders who are using the hitec 5625 servos, did you find that the servos are to long as both servos hit each other when inserted their repective slots? Since the fuselage has a narrow taper near the end its enough for two elevator servos to hit each other. Thinking of adding some scrap balsa to make a spacer to allow the servo clear the other.
