RCU Forums - View Single Post - MVVS .49 Mini pipe glow plug problem!
Old 01-20-2006 | 10:06 AM
DarZeelon's Avatar
DarZeelon
Default RE: MVVS .49 Mini pipe glow plug problem!
No need to apologise, Ricardo.
We are all human and so we err...
I also suggest that you check that your fuel is not old (could have absorbed humidity from the air).
Just to play it safe, get a NEW jug of fuel, with 20% oil, at least half must be Castor and 0-5% nitro.
Make sure you start with the mixture setting quite rich and then, lean it down very gradually.
This engine should not overheat and has excellent cooling in general.
