Thank You! I use construction grade pink foam, (
www.owenscorning.com ) it sand real good and there is less fumes when cutting with a hot wire, in fact I cut it in the basement without a exhaust fan, the blue is also good but stinks and cutting should be done outside, both of those sands just like wood. might be a little heavier than the white foam?
roltech
