RE: Air Hogs Aero Ace!
Hi Skypix,
If you think about it, the engineers at the Air Hogs company probably had to set the engine spacing so an 8 year old wouldn't auger into the ground on every flight. When you move the engines outboard , it becomes more sensitive to turning input. It takes a few flights before you realize that you have to go easy on the "rudder", but after that its all good. I use Cyanocrylate glue that I got from a hobby shop to mount the engines. Its thicker and slower curing than the regular super glue you can get anywhere. Once it bonds, the engines never come off.
Sal
