if i may suggest lower needle little bit at a time till its right counterclockwise .if its boggy yune upper needle clockwise bit at a time .oops sorry had that reversed .this is the my tuning technique .i had the stock t15 ripping and floating on air couldnt believe my own eyes .it is as if i had a whole different motor.
ORIGINAL: Blowerz
Ight guys erm i am still yet to tune the low speed needle because there is smoke at acceleration and hardly any at full speed so will have tune that to switch that around but my main question is i have a venom fail safe and is it possible to set it up without the engine running? like adjust the pot screw and u will gradually see that it is applyin the brakes or need engine running ?? this only 2 things gotta do then will be having it big time everywhere
